[postgis-devel] More dump comments
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Feb 27 07:13:05 PST 2009
Obe, Regina wrote:
> Also according to this
> http://doxygen.postgresql.org/execTuples_8c-source.html
> It appears that TupleDescGetSlot is obsolete. Does anyone know when it
> became obsolete?
> Interesting part of docs
> 01050 * TupleDescGetSlot - Initialize a slot based on the supplied
> tupledesc
> 01051 *
> 01052 * Note: this is obsolete; it is sufficient to call BlessTupleDesc on
> 01053 * the tupdesc. We keep it around just for backwards
> compatibility with
> 01054 * existing user-written SRFs.
> 01055 */
Hi Regina,
Have a quick browse of anoncvs.postgresql.org, and see in which version
this comment changes. If it's before 8.1 then we would be better off
using the newer equivalent instead.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
