[postgis-devel] Compile trouble of Trunk on MingW
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Wed Jan 7 06:39:12 PST 2009
Obe, Regina wrote:
> I'm still having trouble compiling 1.4 SVN under MingW. It keeps
> complaining that it can't find my Proj install. My install looks fine
> as far as I can tell. The proj.exe etc gets installed. I verified my
> Proj 4.6.1 proj_api.h is in C:\msys\1.0\local\include\proj_api.h
> I tried this
> ./configure --libdir=/usr/local/lib --includedir=/usr/local/include
> --with-pgconfig=/usr/local/pgsql/bin/pg_config
> --with-projdir=/usr/local/include
> and keep getting the error
> configure: error: could not find proj_api.h - you may need to specify
> the directory of a PROJ.4 installation using --with-projdir
> I tried using both SVN and nightly snapshot with same error. Have no
> clue what I am missing here.
> GEOS seems to be automatically detected and pgconfig seem to work fine
> with the --with-pgconfig.
> Any thoughts would be appreciated.
> Thanks,
> Regina
Hi Regina,
The clue is in the name ;) projdir needs to point to base directory of
the PROJ.4 install, since it needs the information from various
subdirectories. In your case above, it should work with
--with-projdir=/usr/local.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
