[postgis-devel] Memory Leak (Two Senses)
Paul Ramsey pramsey at opengeo.org
Wed Jan 7 08:46:51 PST 2009
Thanks for all the detailed info, Mark!
I agree that our LWGEOM data structure should be aligned and directly
accessible, but I would go one further and say we should align our
serialized structure. Basically retain the aspect of Dave's design
that uses the serialized version directly, but alter the serialized
version enough to align it internally.
Why so? As you note, that data is const, we can't muck with it.
HOWEVER, most operations people are running in the database are
read-only with respect to the spatial data. They are using it as a
query parameter, or a filter, or they are just flipping it out to a
different format (maps, or GML, JSON or whatnot).  AND, in those cases
where geometry IS being altered, it is usually being done in a
constructive manner: that is, whole new geometries are being created
(buffer, union, difference, etc).
I think where we both end up is in a place where we need some way of
noting what kind of geometry we have on hand, a const one or a
variable one, so we can "do the right thing" in a number of situations
(freeing, trying to alter, etc).
And think, if you're getting that good throughput memcpy'ing the whole
block, how fast will it be when you're directly accessing an aligned
tuple? :) W00t!
P.
On Wed, Jan 7, 2009 at 2:50 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> The second memory leak. The lwfree_pointarray function is defined in
>> lwgeom_api, and it is directly below a comment block that says *this*:
>>  * memory management
>>  *  these only delete the memory associated
>>  *  directly with the structure - NOT the stuff pointing into
>>  *  the original de-serialized info
>> Oh! That seems pretty clear. So by changing the function to fully
>> clean up after itself, I'm contravening the documented intent.
>> However, grep tells me the function is but lightly used in the code
>> base, hardly at all, really.  Our second memory leak is historical, we
>> have no idea why the intent was once this way.
>> Before I commit the changes to the lwfree_* set to make them finally,
>> actually, do deep freeing, can anyone provide the historical context
>> around the rules I seem to want to break?
> Yes - if you do this it will break liblwgeom use within PostgreSQL :( Before
> I was ill over Christmas, I started looking at your complaint about
> manipulating MULTI-geoms in liblwgeom, and realised that the reason the
> LWGEOMs are deep-copied is because the POINTARRAYs within LWGEOM *obtained
> from PostgreSQL* MUST be immutable. Hence if we wish to alter a LWGEOM, we
> *MUST* copy it and return the copy.
> And why is this? It's because when PostgreSQL passes us a geometry, we are
> passed a copy of the geometry allocated by PostgreSQL. But the LWGEOM
> deserialization code sets the POINTARRAY pointer directly to the doubles
> array within the PostgreSQL geometry - hence the memory within the
> POINTARRAY *is not ours to free*. This is why there are lots of separate
> lwfree(line->pa)-type calls scattered around liblwgeom to free the parts we
> know can be discarded, but otherwise the memory has to be freed by
> PostgreSQL.
> Since I've been spending a lot of time re-working liblwgeom over the past
> few months, I (and I think you also) have separately come to the conclusion
> that having this type of memory model is not good. The principle of least
> surprise dictates that lwfree()-ing a geometry should free all of it, and
> not assume any behaviour on the part of the environment using the geometry.
> Part of the testing I was doing over Christmas involved experimenting with
> memcpy() to see what the impact would be of copying the POINTARRAY out of
> the PostgreSQL allocated geometry so that the geometries are separate - and
> I came up with some very surprising results. I know strk was keen to
> optimise the performance of the LWGEOMs, but from my results I think there
> has been a case of premature optimisation here.
> The attached file testmem.c is used to compare the performance of LWGEOM
>  construction on an array of 80,000 2D points. The first test is designed to
> compare the difference between scanning through the point array using the
> existing getPoint2d_p() function (unaligned memcpy access) and scanning
> through an aligned array of doubles:
> Testing unaligned point access...
> x: -2.6378e+08
> y: -3.66648e+08
> x: 2.13081e+09
> y: 8.59704e+08
> x: 1.01699e+09
> y: -1.04434e+09
> x: 4.88672e+08
> y: 6.35536e+08
> x: -5.43084e+08
> y: -6.452e+08
> Execution time: 0.26586 s
> (Speed: 300910 points per second)
> Testing aligned point access...
> x: -2.6378e+08
> y: -3.66648e+08
> x: 2.13081e+09
> y: 8.59704e+08
> x: 1.01699e+09
> y: -1.04434e+09
> x: 4.88672e+08
> y: 6.35536e+08
> x: -5.43084e+08
> y: -6.452e+08
> Execution time: 0.0176489 s
> (Speed: 4.53285e+06 points per second)
> Wow. This goes back to your original idea with respect to the speed of
> aligned/versus unaligned access and we can see that the aligned version
> blows away the unaligned version in terms of access speed. So then the
> question to ask is that if we were to memcpy() the unaligned point array
> into an aligned double array when constructing the LWGEOM, would this still
> be faster than access the unaligned array? And the answer is a resounding
> yes:
> Testing non-memcpy lwline constructor with point iteration...
> Execution time: 1.01137 s
> (Speed: 79100.2 points per second)
> Testing memcpy lwline constructor with point iteration...
> Execution time: 0.368717 s
> (Speed: 216969 points per second)
> This test shows the time taken to memcpy() the POINTARRAY and also iterate
> through all of the points within it. The results clearly show that if we
> visit every point in the geometry (which we have to do if we call serialize
> to send the LWGEOM back to PostgreSQL anyway), then even with the initial
> memcpy() from unaligned to aligned memory, the aligned version is still
> nearly 3 times faster than the unaligned version! :O
> Now there is a slight degenerate case here: what if we simply want to access
> a single point within the geometry? This is demonstrated by this case here:
> Testing non-memcpy lwline constructor with single point access (middle
> point)...
> Execution time: 0.0055759 s
> (Speed: 1.43475e+07 points per second)
> Testing memcpy lwline constructor with single point access (middle point)...
> Execution time: 29.0237 s
> (Speed: 2756.37 points per second)
> Ouch. So if we don't visit all points within the memcpy() point array then
> the overhead of the memcpy() becomes quite substantial. This then led me to
> think about LWGEOM_INSPECTED which is supposed to be for high-speed access -
> perhaps we can make use of this? Unfortunately this makes use of the
> serialized form which is only something that would be useful to PostGIS and
> not other users of liblwgeom. But it still makes sense to offer a
> non-memcpy() alternative read-only LWGEOM derivative for these cases.
> So in summary, based upon this work I would suggest the following
> recommendations:
> - Alter the deserialize routines to memcpy() the unaligned pointarray into
> aligned liblwgeom allocated memory
> - Swap liblwgeom code over access the arrays directly instead of using
> getPoint2d_p()
> - Alter the collection manipulation routines so that they no-longer deep
> copy LWGEOMs
> - Alter the lwfree_* functions so that they free the pointarray copy
> Once liblwgeom manages its own memory in this way are then very close to
> getting rid of the bad hack that is lwgeom_init_allocators() and
> lwgeom_install_default_allocators().
> Then just to complete the icing on the cake:
> - Remove the LWGEOM_INSPECTED routines (I think given the non-alignment of
> these they will also prove to be slower in real life)
> - Create a new LWGEOM_INLINE read-only type which works in a similar manner
> to existing LWGEOM without memcpy(). We can then use this for pulling out
> single unaligned points out of large arrays if required.
> I realise that this is quite a long email, but I think that the attached
> test show there is a strong case for changing the way in which liblwgeom
> which will not only speed up performance for routines which process
> geometries, but will also untangle the liblwgeom memory-management from
> PostgreSQL (which as Paul notes will make it much easier to detect memory
> leaks) :)
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
