[postgis-devel] Issue 82 in postgis: Bug in bug tracker
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 02:33:09 PST 2009
Comment #2 on issue 82 by mark.cav... at siriusit.co.uk: Bug in bug tracker
http://code.google.com/p/postgis/issues/detail?id=82
I've just changed the sorting order again based upon Milestone / Priority /
Id so it
should make it easier to see which bugs are new, and which ones we need to
close to
do a release.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
