[postgis-devel] Issue 97 in postgis: Rename LWCURVE to LWCIRCSTRING
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 03:27:27 PST 2009
Status: Accepted
Owner: mark.cav... at siriusit.co.uk
Labels: Milestone-1.4
New issue 97 by mark.cav... at siriusit.co.uk: Rename LWCURVE to LWCIRCSTRING
http://code.google.com/p/postgis/issues/detail?id=97
See explanation here:
http://postgis.refractions.net/pipermail/postgis-devel/2008-December/004421.html
The confusion stems from the fact that internally what we call a curve is
actually a circularstring; hence when reading code it gets very confusing
since in the SQL-MM spec, a curve is an abstract supertype and not a real
type.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
