[postgis-devel] Issue 34 in postgis: .prj creation by pgsql2shp
codesite-noreply at google.com
Fri Jan 9 03:59:33 PST 2009
Updates:
Status: Fixed
Comment #21 on issue 34 by robe.... at cityofboston.gov: .prj creation by
pgsql2shp
http://code.google.com/p/postgis/issues/detail?id=34
I'm all for closing this out. Someone can reopen it if they feel the
need. I've
tested the 1.3.6 under OpenSUSE, Vista, and Windows 2000 and seems to
generate the
.prj fine. I've only tested the 1.4 under OpenSUSE, but plan to test 1.4
under
Windows 2000, XP and Vista before release.
I have opened both OpenSUSE and Windows generated with ArcGIS 9.3 on a
Windows 2000
and that seems to overlay them correctly against other data in another
projection.
Also had someone else do the same test under Windows XP (ArcGIS 9.3). He
said it worked.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
