[postgis-devel] Issue 19
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Sat Jan 10 04:54:48 PST 2009
Paul Ramsey wrote:
> http://code.google.com/p/postgis/issues/detail?id=18
> Mark, you've upgraded this to 1.4, so we should discuss. Your comment in
> the 8.4 block indicates you think we do need to re-check. I'm pretty
> sure right now our re-check just testings the float4 boxes again, so it
> doesn't accomplish anything. And I'm not sure our contract with users is
> to be anything but inexact (but overdetermined) on index searches.
> Now, I think Kevin has some use cases where the float4 round causes
> issues. I guess "group by" for points, yes? I think that the use case of
> "faster for large geometries" outweighs the use case of "group by for
> points", but I could be wrong.
> P.
It wasn't supposed to be like that, although re-reading it now I see
that it comes across differently than was intended. At the end of the
day, there needs to be a compromise between usability and performance -
and while I was originally for the RECHECK to help beginners, we now
have a reasonable body of evidence that shows we are seriously
penalising performance on large databases. So given that Kevin has a
work-around, it makes more sense to add a note to the documentation and
make the change.
> PS - I see the recheck value getting set in the gist_consistent test,
> but where does the recheck then occur, if we return true?
The RECHECK is performed by the executor; the query planner inserts an
extra join filter condition to re-evaluate the geometry as the join is
executed.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
