[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com
Sat Jan 10 22:26:14 PST 2009
Comment #2 on issue 94 by pwramsey3: Rename folders/files to be more
consistent
http://code.google.com/p/postgis/issues/detail?id=94
Re-naming commonly known things (this name has been around for a while now)
is generally bad, but since
we've already *moved* the file, we might as well re-name it too. I wish we
could put a number on it without
breaking other things... postgis-14.sql. But then we'd have to number our
so/dlls and then upgrades would get
even tricker, and then...
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
