[postgis-devel] Issue 18 in postgis: Remove RECHECK requirement on index
codesite-noreply at google.com codesite-noreply at google.com
Mon Jan 12 08:24:18 PST 2009
Comment #5 on issue 18 by pwramsey3: Remove RECHECK requirement on index
http://code.google.com/p/postgis/issues/detail?id=18
Regressing for performance is practically impossible, as far as I know. If
we were a huge organizations, we would
maintain a set of older versions we could run a performance regression
suite on, but we're not, and I cannot
think of any general purpose way to build performance improvement testing
into our regression suite so it could
make a meaningful determination with just one copy of the software.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
