[postgis-devel] GeoJSON failing on 1.4
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Jan 13 06:41:10 PST 2009
Obe, Regina wrote:
> Yap works now for both geojson and kml so its still just that nagging
> regress_bdpoly which I guess we haven't resolved yet.
It actually comes down to your current discussion on the GEOS list about
the Z coordinate:
http://lists.osgeo.org/pipermail/geos-devel/2009-January/003839.html.
For some reason, ST_BuildArea() returns the wrong Z coordinate for the
regression tests which causes the returned polygon to have an unclosed
ring if you consider 3 dimensions. You can clearly see this from the
following output on 1.3:
postgis13=# select st_asewkt(st_geomfromtext('SRID=2;LINESTRING(0 0 2,
10 0 4, 10 10 6, 0 10 8, 0 0 10)'));
WARNING: OGC WKT expected, EWKT provided - use GeomFromEWKT() for this
CONTEXT: SQL function "st_geomfromtext" statement 1
st_asewkt
SRID=2;LINESTRING(0 0 2,10 0 4,10 10 6,0 10 8,0 0 10)
(1 row)
postgis13=# select
st_asewkt(st_buildarea(st_geomfromtext('SRID=2;LINESTRING(0 0 2, 10 0 4,
10 10 6, 0 10 8, 0 0 10)')));
st_asewkt
SRID=2;POLYGON((0 0 10,0 10 8,10 10 6,10 0 4,0 0 2))
(1 row)
Since 1.4 nicely unifies the parser/unparser code, the back-conversion
from GEOS to EWKT now trips the closed ring check which is why we now
see the error.
I think the issue on hand is how closure is defined in the spec for
geometries with > 2 dimensions, and hence whether the bug lies within
GEOS or not. Martin, any comments?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
