[postgis-devel] GeoJSON failing on 1.4
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Tue Jan 20 01:47:57 PST 2009
Martin Davis wrote:
> AFAIK the SFS spec is silent on how "closed" should be defined in the
> Z-dimension.
> FWIW JTS (and I assume GEOS) explicitly does not check the Z-ordinate
> when checking whether a ring is closed or not. But JTS doesn't really
> try to provide full 2.5 D semantics - since you're trying to address
> this in PostGIS, you might want to take a more rigorous approach.
> M
Thanks Martin.
So folks, is this a GEOS bug?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
