[postgis-devel] CascadedUnion Early Results
Kevin Neufeld kneufeld at refractions.net
Tue Jan 20 13:22:23 PST 2009
That's impressive.  Good work Paul!
-- Kevin
Paul Ramsey wrote:
> For completeness, the whole table, about 4x faster:
> uniontest=# select count(*) from counties;
>  count
>   3140
> (1 row)
> uniontest=# select st_area(st_union(the_geom)) from counties;     st_area
>  1095.88034519544
> (1 row)
> Time: 42352.399 ms
> uniontest=# select st_area(st_union_fast(the_geom)) from counties;
>      st_area
>  1095.88034519544
> (1 row)
> Time: 11493.832 ms
> On Jan 20, 2009, at 1:11 PM, Paul Ramsey wrote:
>> Looks good so far. Still chasing down an issue with GEOS before I can
>> commit, but here's the current results:
>> uniontest=# select st_area(st_union(the_geom)) from counties where
>> state_name = 'Texas';
>>     st_area
>> 65.0596422159988
>> (1 row)
>> Time: 702.491 ms
>> where state_name = 'Texas';
>>     st_area
>> 65.0596422159988
>> (1 row)
>> Time: 216.526 ms
>> In the final commit there will just be one st_union() that does the
>> right thing. I made two so I could do comparisons like the above more
>> easily. Perhaps I should leave in a legacy st_union_slow() for people
>> to compare with...
>> Paul Ramsey
>> OpenGeo - http://opengeo.org
>> Putting the "Po" in "PostGIS".
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> Paul Ramsey
> pramsey at cleverelephant.ca
> +1 250 885 0632
