[postgis-devel] CascadedUnion Early Results
Obe, Regina robe.dnd at cityofboston.gov
Tue Jan 20 13:42:35 PST 2009
Paul,
I think we can do better.
As I recall with my cascade union tests I was getting comparable speed
and JTS was about 2-10 times faster.
Can you test the attached data set out.  Then it will be a closer
comparison.  I think for this set JTS was about 20 seconds.
Below is the link to my results on this way back.
http://postgis.refractions.net/support/wiki/index.php?PL%2FPGSQL%20Pseud
o%20Cascade%20Union%20Aggregate%20Function
(though I don't have the JTS one listed there)
Damn I hope this is the right dataset.  I'll retest on my other box but
I have so many of these lying around.
Would also be interesting to repeat Kevin's original test that started
this all out.  I can send you that dataset off list.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Tuesday, January 20, 2009 4:34 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] CascadedUnion Early Results
Paul Ramsey wrote:
> For completeness, the whole table, about 4x faster:
> uniontest=# select count(*) from counties;
>  count
>   3140
> (1 row)
> uniontest=# select st_area(st_union(the_geom)) from counties;
st_area
>  1095.88034519544
> (1 row)
> Time: 42352.399 ms
> uniontest=# select st_area(st_union_fast(the_geom)) from counties;
>      st_area
>  1095.88034519544
> (1 row)
> Time: 11493.832 ms
Fascinating. What would be really interesting would be to compare the
times with the same dataset in JTS so we can get a feel as to whether
there is any more overhead in the array_accum/GEOS conversion code.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
Type: application/x-zip-compressed
Desc: usstatebounds.zip
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090120/0bb8bf90/attachment.bin>
