[postgis-devel] Issue 100 in postgis: postgis_restore.pl createdb option wrong usage
codesite-noreply at google.com codesite-noreply at google.com
Tue Jan 20 14:00:32 PST 2009
Status: New
Owner: ----
New issue 100 by htmledit: postgis_restore.pl createdb option wrong usage
http://code.google.com/p/postgis/issues/detail?id=100
In the Postgis 1.3.5 release, the 'postgis_restore.pl' contrib file allow
the user to specify createdb options.
In a recent issue (#45 :
http://code.google.com/p/postgis/issues/detail?id=45&can=1&q=postgis_restore.pl),
the createdb option was extended to createlang ans psql commands.
Though, createdb/createlang/psql do not accept the same options !
For example if you specify --encoding=LATIN9 for createdb, an error occurs
while executing "createlang --encoding=LATIN9" and "psql
--encoding=LATIN9"...
Maybe we should add more options arguments specific to createlang and psql.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
