[postgis-devel] Another Data Point
Obe, Regina
robe.dnd at cityofboston.gov
Wed Jan 21 05:17:39 PST 2009
Ah I think JTS was able to do this in about 40-50 seconds. And my
version was able to beat out Kevin's nested by a small margin. I'll
retest on mine.
So I think we still need work here.
I'm curious what would happen if I combined the algorithm I wrote with
the new ST_Union how things would fair. In theory it should fair the
same, but I'm not really using Martin's cascaded union algorithm to the
letter.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, January 21, 2009 12:50 AM
To: PostGIS Development Discussion
Cc: lee.keel at uai.com
Subject: [postgis-devel] Another Data Point
Using the original sample set from Lee Keel,
With the old style ST_Union, 3 hours, 27 minutes:
uniontest=# select st_area(st_union(the_geom)) from sample_poly;
st_area
0.0324039850011104
(1 row)
Time: 12419261.819 ms
With the new cascaded ST_Union, 4 minutes, 30 seconds, or 46 times
faster.
uniontest=# select st_area(st_union_fast(the_geom)) from sample_poly;
st_area
0.0324039850054305
(1 row)
Time: 271618.181 ms
That's one nasty data set.
P.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
