[postgis-devel] Another Data Point
Paul Ramsey
pramsey at cleverelephant.ca
Wed Jan 21 09:05:25 PST 2009
Interesting! The Shark only samples for about 20 seconds, so I only
got the first 10% or so of the run, and the biggest user in that time
period memcpy'ing in LWGEOM_accum (postgis) and
advance_transition_function (pgsql). So we are spending a non-trivial
amount of time just accumulating the input...
P
On Wed, Jan 21, 2009 at 9:00 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> The glove is dropped indeed... why speculate when I have the Shark...
> time to see where our time goes...
> P
> On Wed, Jan 21, 2009 at 8:55 AM, Martin Davis <mbdavis at refractions.net> wrote:
>> Go for it, Regina! The glove is dropped...
>> Although I suspect this test may simply be running into the slower memory
>> performance due to any or all of Postgres, C, GEOS compared to good ol'
>> Java... Hard to beat that tuned JVM memory manager!
>> Obe, Regina wrote:
>>> Ah I think JTS was able to do this in about 40-50 seconds. And my
>>> version was able to beat out Kevin's nested by a small margin. I'll
>>> retest on mine.
>>> So I think we still need work here.
>>> I'm curious what would happen if I combined the algorithm I wrote with
>>> the new ST_Union how things would fair. In theory it should fair the
>>> same, but I'm not really using Martin's cascaded union algorithm to the
>>> letter.
>>> -----Original Message-----
>>> From: postgis-devel-bounces at postgis.refractions.net
>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>>> Ramsey
>>> Sent: Wednesday, January 21, 2009 12:50 AM
>>> To: PostGIS Development Discussion
>>> Cc: lee.keel at uai.com
>>> Subject: [postgis-devel] Another Data Point
>>> Using the original sample set from Lee Keel,
>>> With the old style ST_Union, 3 hours, 27 minutes:
>>> uniontest=# select st_area(st_union(the_geom)) from sample_poly;
>>> st_area
>>> 0.0324039850011104
>>> (1 row)
>>> Time: 12419261.819 ms
>>> With the new cascaded ST_Union, 4 minutes, 30 seconds, or 46 times
>>> faster.
>>> uniontest=# select st_area(st_union_fast(the_geom)) from sample_poly;
>>> st_area
>>> 0.0324039850054305
>>> (1 row)
>>> Time: 271618.181 ms
>>> That's one nasty data set.
>>> P.
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
>> Martin Davis
>> Senior Technical Architect
>> Refractions Research, Inc.
>> (250) 383-3022
