[postgis-devel] overlaps left
Kevin Neufeld
kneufeld at refractions.net
Wed Jan 21 14:39:08 PST 2009
The docs said that &> returned true if the bounding boxes overlap OR is to the left of ...
That doesn't seem to be the case:
SELECT tbl1.column1, tbl2.column1,
tbl1.column2 && tbl2.column2 AS overlaps,
tbl1.column2 &< tbl2.column2 AS overlapsleft
FROM
( VALUES
(1, 'LINESTRING( 1 2, 4 6 )'::geometry)) AS tbl1,
( VALUES
(2, 'LINESTRING( 0 0, 3 3 )'::geometry)) AS tbl2;
column1 | column1 | overlaps | overlapsleft
1 | 2 | t | f
(1 row)
-- Kevin
