[postgis-devel] Another Data Point
Martin Davis
mbdavis at refractions.net
Wed Jan 21 16:18:23 PST 2009
I'm dancing!
Obe, Regina wrote:
> Okay you can dance. I'll say its a tie so all can dance :)
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul
> Ramsey
> Sent: Wed 1/21/2009 3:17 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Another Data Point
> 15 seconds on OpenJump. I'll take my victories where I can get them,
> this is close enough.
> P
> On Wed, Jan 21, 2009 at 11:53 AM, Obe, Regina
> <robe.dnd at cityofboston.gov> wrote:
> > I don't have my OpenJump available at the moment.
> > Kevin or Paul you happen to have that? If not then I guess I can test
> > tomorrow and
> > then Paul can do his little dance :)
> > Though would make more sense for Paul to do it so we are testing on
> the same
> > hardware.
> Paul Ramsey
> > Sent: Wed 1/21/2009 2:50 PM
> > Now can I do my little dance?
> > uniontest=# SELECT geometrytype(_unite_garray_fast(ARRAY(SELECT
> > the_geom FROM sample_poly)));
> > geometrytype
> > MULTIPOLYGON
> > (1 row)
> > Time: 24122.901 ms
> > uniontest=#
> > On Wed, Jan 21, 2009 at 11:43 AM, Obe, Regina
> > wrote:
> >> Paul,
> >> I wouldn't proclaim victory on that alone.
> >> Do another test. 20 seconds sounds a little too short.
> >> I'm not saying it isn't right and my memory may be wrong on the JTS
> result
> >> too.
> >> Besides JTS would have to collect geometries as well I imagine so you
> >> can't
> >> simply throw that out and proclaim victory.
> >> Test out
> >> SELECT geometrytype(st_unite_garray(ARRAY(SELECT the_geom FROM
> >> sample_poly)))
> >> Though that wouldn't be quite a true test either. But somewhere between
> >> the
> >> two would be the answer.
> >> Ramsey
> >> Sent: Wed 1/21/2009 1:58 PM
> >> Well, just running this:
> >> uniontest=# select geometrytype(collect(the_geom)) from sample_poly;
> >> geometrytype
> >> GEOMETRYCOLLECTION
> >> (1 row)
> >> Time: 261624.195 ms
> >> takes 251 of the 271 seconds the union operation took... the
> >> implication is that the GEOS portion of the work is on the order of 10
> >> seconds.
> >> P.
> >> On Wed, Jan 21, 2009 at 10:10 AM, Martin Davis
> <mbdavis at refractions.net>
> >> wrote:
> >>> Could be... It would be interesting to see whether GEOS is
> faster than
> >>> JTS. Needs a test environment able to run both pieces of code on the
> >>> same
> >>> hardware.
> >>> Paul Ramsey wrote:
> >>>> I got another run in, right near the end, and it showed that
> >>>> GEOSUnionCascaded took only about 50% of the time in that slice.
> There
> >>>> was still more memcpy'ing first. I bet GEOSUnionCascaded on its own
> >>>> would be as fast as JTS (or faster?).
> >>>> P.
> >>>> On Wed, Jan 21, 2009 at 9:05 AM, Paul Ramsey
> <pramsey at cleverelephant.ca>
> >>>> wrote:
> >>>>> Interesting! The Shark only samples for about 20 seconds, so I only
> >>>>> got the first 10% or so of the run, and the biggest user in that
> time
> >>>>> period memcpy'ing in LWGEOM_accum (postgis) and
> >>>>> advance_transition_function (pgsql). So we are spending a
> non-trivial
> >>>>> amount of time just accumulating the input...
> >>>>> P
> >>>>> On Wed, Jan 21, 2009 at 9:00 AM, Paul Ramsey
> >>>>> wrote:
> >>>>>> The glove is dropped indeed... why speculate when I have the
> Shark...
> >>>>>> time to see where our time goes...
> >>>>>> P
> >>>>>> On Wed, Jan 21, 2009 at 8:55 AM, Martin Davis
> >>>>>> wrote:
> >>>>>>> Go for it, Regina! The glove is dropped...
> >>>>>>> Although I suspect this test may simply be running into the slower
> >>>>>>> memory
> >>>>>>> performance due to any or all of Postgres, C, GEOS compared to
> good
> >>>>>>> ol'
> >>>>>>> Java... Hard to beat that tuned JVM memory manager!
> >>>>>>> Obe, Regina wrote:
> >>>>>>>> Ah I think JTS was able to do this in about 40-50 seconds.
> And my
> >>>>>>>> version was able to beat out Kevin's nested by a small
> margin. I'll
> >>>>>>>> retest on mine.
> >>>>>>>> So I think we still need work here.
> >>>>>>>> I'm curious what would happen if I combined the algorithm I wrote
> >>>>>>>> with
> >>>>>>>> the new ST_Union how things would fair. In theory it should fair
> >>>>>>>> the
> >>>>>>>> same, but I'm not really using Martin's cascaded union
> algorithm to
> >>>>>>>> the
> >>>>>>>> letter.
> >>>>>>>> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of
> >>>>>>>> Paul
> >>>>>>>> Ramsey
> >>>>>>>> Sent: Wednesday, January 21, 2009 12:50 AM
> >>>>>>>> Cc: lee.keel at uai.com
> >>>>>>>> Subject: [postgis-devel] Another Data Point
> >>>>>>>> Using the original sample set from Lee Keel,
> >>>>>>>> With the old style ST_Union, 3 hours, 27 minutes:
> >>>>>>>> uniontest=# select st_area(st_union(the_geom)) from sample_poly;
> >>>>>>>> st_area
> >>>>>>>> 0.0324039850011104
> >>>>>>>> (1 row)
> >>>>>>>> Time: 12419261.819 ms
> >>>>>>>> With the new cascaded ST_Union, 4 minutes, 30 seconds, or 46
> times
> >>>>>>>> faster.
> >>>>>>>> uniontest=# select st_area(st_union_fast(the_geom)) from
> >>>>>>>> sample_poly;
> >>>>>>>> st_area
> >>>>>>>> 0.0324039850054305
> >>>>>>>> (1 row)
> >>>>>>>> Time: 271618.181 ms
> >>>>>>>> That's one nasty data set.
> >>>>>>>> P.
> >>>>>>>> _______________________________________________
> >>>>>>>> postgis-devel mailing list
> >>>>>>>> postgis-devel at postgis.refractions.net
> >>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> >>>>>>>> The substance of this message, including any attachments, may be
> >>>>>>>> confidential, legally privileged and/or exempt from disclosure
> >>>>>>>> pursuant to Massachusetts law. It is intended
> >>>>>>>> solely for the addressee. If you received this in error, please
> >>>>>>>> contact the sender and delete the material from any computer.
> >>>>>>> Martin Davis
> >>>>>>> Senior Technical Architect
> >>>>>>> Refractions Research, Inc.
> >>>>>>> (250) 383-3022
> >>> Martin Davis
> >>> (250) 383-3022
> pursuant to
> >> Massachusetts law. It is intended solely for the addressee. If you
> >> received
> >> this in error, please contact the sender and delete the material
> from any
> >> computer.
> >> Help make the earth a greener place. If at all possible resist printing
> >> this
> >> email and join us in saving paper.
> pursuant to
> received
> from any
> > computer.
> printing this
> *The substance of this message, including any attachments, may be
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
Martin Davis
(250) 383-3022
