[postgis-devel] Faster Accum
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Jan 22 01:37:13 PST 2009
Paul Ramsey wrote:
> I've started on bringing the 8.4 array_agg back into our tree. Oddly,
> the code for much of it exists in the postgresql tree already, back to
> 8.0, so the amount of in our tree is fairly slight.
Awesome. Well done Paul, the results look really impressive so far...
> Unfortunately,
> because the idea is to pass an internal pointer around, and CREATE
> AGGREGATE doesn't like that, there's some updating of system tables
> required to fully hook it up.
Eeek. Changing the system catalogs in an undocumented manner like this
is an absolute no-no. What should be happening is that we should create
a special type for the transition function (which is essentially a
wrapper on Datum) to hold the ArrayState and use that instead.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
