[postgis-devel] Issue 89 in postgis: transform() grid-shift 2nd chance logic defective
codesite-noreply at google.com codesite-noreply at google.com
Thu Jan 22 08:42:22 PST 2009
Comment #8 on issue 89 by william.... at acm.org: transform() grid-shift 2nd
http://code.google.com/p/postgis/issues/detail?id=89
Thanks, Frank.  I hadn't dug that deeply into proj (and thanks for all you
do there
and on GDAL).  I can hardly do otherwise than gratefully embrace your
analysis and
conclusion.  However ...
1. It would be really nice if proj.4 error handling clearly distinguished
between
missing grid-shift files and transformed points outside the range for which
the grid
shift is defined.
2. The "second chance" logic in PostGIS's lwgeom_transform.c should be
entirely
removed.  It does not do what its comments claim, and, if it did, would
conflict
with the approach you recommend above.
3. It would be helpful to improve PostGIS warning/error messages as I
suggest in the
next to last paragraph of my last message above, at least to the extent
still
relevant with your recommended approach.
I'll be happy to take a swipe at patches for items 2 and 3 above, though
given my
limited C coding skills, it would probably be better for the PostGIS
development
team to do so if resources are available.
-- Bill
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
