[postgis-devel] Issue 99 in postgis: shp2pgsql 'Only import DBF' error.
codesite-noreply at google.com
Thu Jan 22 09:20:49 PST 2009
Comment #3 on issue 99 by robe.... at cityofboston.gov: shp2pgsql 'Only import
DBF' error.
http://code.google.com/p/postgis/issues/detail?id=99
Problem I think was with the DBFReadDeleted. I think it was doing the
reverse of
what it was intended to do pulling in deleted records and leaving out
non-deleted
records. Paul can you verify my logic. Unfortunately I don't have FoxPro
loaded and
I only know how to mark dbf records deleted with FoxPro.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
