[postgis-devel] Faster Accum
Obe, Regina robe.dnd at cityofboston.gov
Thu Jan 22 10:40:00 PST 2009
And how many heads do you have?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Thu 1/22/2009 1:28 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Faster Accum
On Jan 22, 2009, at 1:37 AM, Mark Cave-Ayland wrote:
> Eeek. Changing the system catalogs in an undocumented manner like
> this is an absolute no-no. What should be happening is that we
> should create a special type for the transition function (which is
> essentially a wrapper on Datum) to hold the ArrayState and use that
> instead.
Done. I found that wrapping the ArrayBuildState pointer was easier in
the end, after much banging of heads on desks (both mine).
P.
Paul Ramsey
pramsey at cleverelephant.ca
+1 250 885 0632
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090122/6c6cd823/attachment.html>
