[postgis-devel] Compile issues on MingW trunk
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jan 23 07:42:29 PST 2009
Obe, Regina wrote:
> I tried doing a make clean and
> sh autogen.sh
> on MingW and I'm getting this on autogen and not sure what it means
> /usr/share/aclocal/autoopts.m4:22: warning: underquoted definition of
> AG_PATH_AUTOOPTS
> run info '(automake)Extending aclocal'
> or see
> http://sources.redhat.com/automake/automake.html#Extending%20aclocal
> Can't locate object method "path" via package "Request" (perhaps you
> forgot to load "Request"?) at /usr/share/autoconf/Autom4te/C4che.pm line
> 69, <GEN1> line 111.
> aclocal: autom4te failed with exit status: 127
> Thanks,
> Regina
Hi Regina,
What if you run autogen.sh on your SuSE box to generate configure and
transfer the resulting file across? Does it work then?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
