[postgis-devel] Deprecation Warnings
Paul Ramsey pramsey at opengeo.org
Fri Jan 23 14:30:20 PST 2009
Right. Not even wrappers, just breaking the install into postgis.sql
and postgis_legacy.sql...
P
On Fri, Jan 23, 2009 at 2:25 PM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Hmm although it really wouldn't be deprecate -- it would be lets remove them
> and allow people to reinstate them if they want as Kevin suggested.
> Personally I don't care for warnings -- either keep it or get rid of it.
> Warnings sounds like a lot of wasted log space which will probably only be
> seen by logs and potentially mysteriously slow down applications in the
> process.
> Though I guess we must think of the children (Mapserver, GeoServer and
> ZigGIS and so forth which may be using the old names).  But then I suppose
> anyone using apps relying on deprecated names would just install the wrapper
> patch.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net on behalf of Obe, Regina
> Sent: Fri 1/23/2009 5:06 PM
> To: PostGIS Development Discussion
> Subject: RE: [postgis-devel] Deprecation Warnings
> +2
> From: postgis-devel-bounces at postgis.refractions.net on behalf of David
> William Bitner
> Sent: Fri 1/23/2009 4:51 PM
> Subject: Re: [postgis-devel] Deprecation Warnings
> +1, I like Cake.
> On Fri, Jan 23, 2009 at 2:59 PM, Kevin Neufeld
> <kneufeld at refractions.net>wrote:
>> What if we deprecate the functions as you suggest (and eventually remove
>> them), but provide a sql script that will reinstate them as wrappers to
>> the
>> ST_* methods.  That way, folks can have their cake and eat it too ...
>> upgrade to the latest version without breaking their apps.
>> -- Kevin
>> Paul Ramsey wrote:
>>> Could we use the function creation option
>>> SET configuration_parameter { TO value | = value | FROM CURRENT }
>>> to, for example, set postgis_deprecated to true?
>>> Then in the function, we could warn on deprecation. So the same
>>> backend to intersects() could be used by several function names, but
>>> only some would raise deprecation warnings.
>>> Or do we want to continue our gentle regime of letting the old names
>>> live in quite obscurity?
>>> P.
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
> David William Bitner
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
