[postgis-devel] Function Naming
Obe, Regina robe.dnd at cityofboston.gov
Sun Jan 25 15:58:51 PST 2009
I haven't tried to myself, but then again I have yet to try ArcGIS PostSDE.
I suspect its common because I think from my reading ArcSDE forces you to register each PostSDE service against one database.  I have to verify that.  So lets say you want to make use of ArcSDE only features not supported by the PostGIS datatype, you may have tables using the ESRI geometry type (for example or at leaset as the claim goes ArcSDE curved support is better than PostGIS curve support), but if you want Open source apps to use some tables, you would use the PostGIS datatype.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Mark Cave-Ayland
Sent: Sun 1/25/2009 1:01 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Function Naming
Obe, Regina wrote:
> Does ESRI use GIST as well for their PG_GEOMETRY or whatever they call
> it.  I'm just thinking if we call it geometry  may get confusing for
> people that use both types. Though theirs is in a separate schema anyway
> so doesn't matter I suppose except if someone makes the sde schema a
> global one then we could have some clashes maybe.  Probably not.  Just
> thinking out loud.
Heh. I think anyone who installs both PostGIS and ESRI's geometry type
into the same database should probably have their head examined anyway
:)  Seriously, how could anyone do this and sanely expect it all to work
without any problems??!
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090125/0a69f436/attachment.html>
