[postgis-devel] Issue 108 in postgis: ST_LineToCurve Crashing
codesite-noreply at google.com
Thu Jan 29 21:38:54 PST 2009
Status: New
Owner: ----
New issue 108 by rbroamer: ST_LineToCurve Crashing
http://code.google.com/p/postgis/issues/detail?id=108
What steps will reproduce the problem?
=> SELECT ST_LineToCurve('LINESTRING(-13151357.927248 3913656.64539871,-
13151419.0845266 3913664.12016378,-13151441.323537 3913666.61175286,-
13151456.8908442 3913666.61175286,-13151476.9059536 3913666.61175286,-
13151496.921063 3913666.61175287,-13151521.3839744 3913666.61175287,-
13151591.4368571 3913665.36595828)');
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
This is running on TODAY's PostGIS SVN and GEOS 3.1.0RC1. It's on a 32-bit
Ubuntu 8 LTS box
with PostgreSQL 8.3.5. Had the same problem with 1.3.4.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
