[postgis-devel] Issue 109 in postgis: Some operators not supported for Circular
codesite-noreply at google.com
Fri Jan 30 05:11:18 PST 2009
Status: Accepted
Owner: ----
Labels: Milestone-1.4 Type-Defect Priority-Low
New issue 109 by robe.... at cityofboston.gov: Some operators not supported
for Circular
http://code.google.com/p/postgis/issues/detail?id=109
What steps will reproduce the problem?
1.
SELECT foo1.the_geom ~= foo2.the_geom
FROM ((SELECT
ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)) As the_geom
FROM generate_series(-10,50,10) As i
CROSS JOIN generate_series(40,70, 20) As j)) As
foo1 CROSS JOIN ((SELECT
CROSS JOIN generate_series(40,70, 20) As j)) As foo2
LIMIT 3;
What is the expected output? Either not supported for x and y or for it to
do something
What do you see instead?
psql:torturetest.sql:22279: ERROR: lwgeom_same: unknown geometry type: 13
psql:torturetest.sql:22555: ERROR: lwgeom_same: unknown geometry type: 8
I've only tested against latest 1.4. I'm not sure how hard it is to get
these to support circular or if its important, but should at least give the
type descriptor instead of number.
I also haven't checked log to see how many of these throw this error.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
