[postgis-devel] [PostGIS] #212: compound curve in a curve polygon is flaky
trac at osgeo.org
Wed Jul 1 04:17:17 PDT 2009
Reporter: robe | Owner: mleslie
Type: defect | Status: reopened
Priority: medium | Milestone: postgis 1.4.0
Component: postgis | Version: 1.4
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
The above seems to work for me too now so much better. However -- what am
I doing wrong here?
This works -- I can have an outer ring that is a compound curve and an
inner ring that is a regular closed line:
SELECT ST_GeomFromEWKT('CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(0 0,2 0,
2 1, 2 3, 4 3),(4 3, 4 5, 1 4, 0 0)), (1.7 1, 1.4 0.4, 0.70 0.40, 0.37
0.97, 0.70 1.54, 1.34 1.53, 1.7 1))');
But when I attempt a curved polygon with a compound curve outer ring and a
circular inner ring, can't get it to work.
Here is my simple ring -- seems valid produces a nice cirle as far as I
can tell
SELECt ST_CurveToLine('CIRCULARSTRING(1.7 1, 1.4 0.4, 1.7 1)');
So replacing my above with my ring:
2 1, 2 3, 4 3),(4 3, 4 5, 1 4, 0 0)), CIRCULARSTRING(1.7 1, 1.4 0.4, 1.7
1) )');
I get this error:
ERROR: geometry requires more points
HINT: "...CIRCULARSTRING(1.7 1, 1.4 0.4, 1.7 1)" <-- parse error at
position 126 within geometry
Or do we not support yet curved polygon with compoundcurve and circular
rings?
Mark L did you say you wanted this to be patched in 1.3 as well? I can't
speak for 1.3.7, but for 1.3.6 -- it does not support creating a compound
curve in a curved poly . Gives "parse error invalid geometry" and since
1.3 is in bug fix mode, I don't think we should bother patching it since
doesn't look like the functionality even made it partly in there.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/212#comment:5>
