[postgis-devel] [PostGIS] #212: compound curve in a curve polygon is flaky
PostGIS trac at osgeo.org
Thu Jul 2 01:59:05 PDT 2009
  Reporter:  robe     |       Owner:  mleslie
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  postgis 1.4.0
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by robe):
 Mark -- don't we use ST_NPoints function for checking (or whatever
 function is behind that)?  I thought ST_NumPoints because its OGC defined
 (though we should change to make the same but that's another argument)
 doesn't work for most things anyway though I presume its supposed to work
 for circular strings and compound curves because they fit under the OGC
 Curve hierarchy (same family as linestring).  Just wondering what that has
 to do with this ticket item.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/212#comment:11>
