[postgis-devel] [PostGIS] #217: Compile problem on non-GNU systems (__va_copy)
PostGIS trac at osgeo.org
Sun Jul 5 05:03:52 PDT 2009
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.4.0
 Component:  postgis  |     Version:  1.4
Resolution:           |    Keywords:
Comment (by mcayland):
 Okay great. I seem to remember something in the back of my mind about some
 of the va_args stuff being different between 32-bit/64-bit platforms? Can
 someone check on a 32-bit system and make sure that print output is not
 garbled? (building --with-debug and running a few simple queries would be
 a good test, as I seem to remember that just building was not a good
 enough test to make sure it actually worked).
 ATB,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/217#comment:3>
