[postgis-devel] st_dwithin, st_within, st_dcompletlywithin
nicklas.aven at jordogskog.no
Mon Jul 6 16:19:59 PDT 2009
Hallo
This is a semantic question.
I'm working with the new functions st_shortestline etc.
I found that we can get another new function for free when we have implemented st_max_distance. By using the max-calculation instead of min-calculation the same way as st_dwithin, we insead get "st_dcompletlywithin" the function returns true if the maximum distance between the geometries is shorter than the third input.
My question is (beside the question if this is something useble), what to call the function. I think it easily can be confusing. I mean, st_within and st_dwithin is two quite similar names wich is ok because they don't really relate to eachother in what they do, but if we add a function that do the same as st_dwithin but whith the difference that the geometries has to be completly inside the given distance of eachother, maybe we risk making it confusing. I guess st_dcompletlywithin is maybe the most describing, but very long.
Greetings
Nicklas
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090707/742d0c58/attachment.html>
