[postgis-devel] st_dwithin, st_within, st_dcompletlywithin
Paragon Corporation lr at pcorp.us
Wed Jul 8 15:39:26 PDT 2009
Paul,
I'm sorry.  I see it now :(
http://postgis.refractions.net/documentation/manual-svn/ST_HausdorffDistance
.html
Okay I guess its because it didn't have the big flashing Availability 1.5  I
missed it.
I apologize for my griping.  I guess I should write up some documentation on
how to document :)
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, July 08, 2009 6:31 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] st_dwithin, st_within, st_dcompletlywithin
The patch included a docs patch.
On Wed, Jul 8, 2009 at 3:22 PM, Paragon Corporation<lr at pcorp.us> wrote:
> Oh that's what that is.  Hmm and I think its already ported to
> PostGIS, though would be interesting to compare the speeds and
> results.  Since the current one in trunk is a GEOS call and Nicklas' would
be a native PostGIS.
> http://trac.osgeo.org/postgis/ticket/209
> Paul are you hmm planning add this to the manual -- I see you closed
> it?  I don't recall seeing it in the 1.5 docs or were we waiting for
> GEOS to be patched first?
> Thanks,
> Regina
> Martin Davis
> Sent: Wednesday, July 08, 2009 6:14 PM
> st_dcompletlywithin
> That distance metric is known as the Hausdorff Distance.  It's
> implemented in JTS, and probably in GEOS as well.
> nicklas.aven at jordogskog.no wrote:
>> A function that gives the answer to for example:
>> "How far away from France can you get in Belgia"
>> To answer that we have to store compare the shortest distance to
>> geometry2 from each vertex in geometry1 and finaly find wich vertex
>> in
>> geometry1 that has the highest "mindistance" to geometry2.
>> Hope the idee is possible to understand. Is it of any use?
> Martin Davis
> Senior Technical Architect
> Refractions Research, Inc.
> (250) 383-3022
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
