[postgis-devel] why this difference when sub-query
Paragon Corporation
lr at pcorp.us
Mon Jul 13 01:27:38 PDT 2009
Nicklas,
That is odd. And of course this works
SELECT st_astext(geom1) from
(SELECT CAST(NULL As geometry) as geom1) a;
All I can say is counting on autocasts is evil.
My guess what is happening is when you create the virtual table -- it
automatically autocasts it to an unknown because there is no data type where
as when fed directly to a function NULL has not been CAST yet so it can be
CAST to anything and since ST_AsText only accepts geometry, the NULL gets
cast to a geometry as a result of being fed into ST_AsText.
So your fallacy is assuming that NULL and unknown are the same thing. They
are NOT. NULL can be cast to anything and unknown can not.
Observe this - yap works fine - I rest my case - in this case, PostgreSQL
finds the likely data type for the virtual column -- in this case it would
be a geometry
since NULL can be cast to anything, and all the values in the column need to
be cast to the same thing
(select NULL as geom1
UNION ALL
SELECT ST_GeomFromText('LINESTRING(1 2, 3 4)') As geom1
) a;
Hope that helps,
Regina
_____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
nicklas.aven at jordogskog.no
Sent: Monday, July 13, 2009 4:08 AM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] why this difference when sub-query
I'm working on the regression-tests for the distance-functions and don't
really understand the behavior of postgis or the planner or what it is,
doing it.
if I run:
select st_astext(geom1) from
(select NULL as geom1) a;
I get:
FEIL: failed to find conversion function from unknown to geometry
********** Error **********
SQL state: XX000
but if I run:
select st_astext(NULL)
or
select st_astext(NULL) from
then I just get an empty answer without error-message.
and if I run :
select geom1 from
I also get just an empty answer.
Why is this conversion-function trigged when I use a sub-query and not
otherwise and only if I use the NULL-value in a function and not if I just
show it.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/0d4ff4cb/attachment.html>
