[postgis-devel] problem with makefile in MinGW in trunk
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Jul 13 02:54:06 PDT 2009
nicklas.aven at jordogskog.no wrote:
> I downloaded 1.4 branch and tested.
> "make clean" gives exactly the same error as the trunk
> "make check" gives this after a successfull cunit-test:
> make -C regress check
> make[1]: Entering directory `/c/thesrc/pg14/regress'
> make -C ../postgis
> make[1]: make: Command not found
> make[1]: *** [../postgis/postgis.so] Error 127
> make[1]: Leaving directory `/c/thesrc/pg14/regress'
> make: *** [check] Error 2
Hmmm if you revert r4134 from trunk, does that fix the issue? You might
need to do some experimentation with "make" to find exactly what is
happening to PATH before and after those lines in trunk...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
