[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Mon Jul 13 11:12:28 PDT 2009
yes, exactly the same as me.But this is a new fenomena. Not very long time ago it worked fine, butnow both the trunk and 1.4 branch gives the same error.I found an old makefile (in regression folder) from a few months ago and commented some rows that differed from the old one, as described earlier in this thread and then "make clean" worked again. But make check still didn't work. I don't know if there is anything in common between the errors, but in both cases it is screaming after commands that should be available. /Nicklas
2009-07-13 Paragon Corporation wrote:
We get a path not found error too when doing make clean.
>In our case says rm cannot be found.
>When do
>$PATH
>In mingw, gives a truncated path and error No such file or directory
>Below is the make clean log
>make -C liblwgeom clean
>make[1]: Entering directory `/c/thesrc/postgis-1.4.0rc2/liblwgeom'
>rm -f measures.o box2d.o ptarray.o lwgeom_api.o lwgeom.o lwpoint.o lwline.o
>lwpoly.o lwmpoint.o lwmline.o lwmpoly.o lwcollection.o lwcircstring.o
>lwcompound.o lwcurvepoly.o lwmcurve.o lwmsurface.o lwutil.o lwalgorithm.o
>lwgunparse.o lwgparse.o lwsegmentize.o wktparse.tab.o lex.yy.o vsprintf.o
>rm -f liblwgeom.a
>make[1]: Leaving directory `/c/thesrc/postgis-1.4.0rc2/liblwgeom'
>make -C postgis clean
>make[1]: Entering directory `/c/thesrc/postgis-1.4.0rc2/postgis'
>rm -f postgis-1.4.dll libpostgis-1.4.a libpostgis-1.4dll.def
>rm -f postgis.sql uninstall_postgis.sql postgis_upgrade.sql
>rm -f lwgeom_pg.o lwgeom_debug.o lwgeom_accum.o lwgeom_spheroid.o
>lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o lwgeom_estimate.o
>lwgeom_functions_basic.o lwgeom_gist.o lwgeom_btree.o lwgeom_transform.o
>lwgeom_box.o lwgeom_box3d.o lwgeom_box2dfloat4.o lwgeom_chip.o lwgeom_geos.o
>lwgeom_geos_prepared.o lwgeom_svg.o lwgeom_gml.o lwgeom_kml.o
>lwgeom_geojson.o lwgeom_triggers.o lwgeom_dump.o lwgeom_functions_lrs.o
>long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
>rm -f postgis.sql.in uninstall_postgis.sql.in
>make[1]: Leaving directory `/c/thesrc/postgis-1.4.0rc2/postgis'
>make -C loader clean
>make[1]: Entering directory `/c/thesrc/postgis-1.4.0rc2/loader'
>make[1]: Leaving directory `/c/thesrc/postgis-1.4.0rc2/loader'
>make -C doc clean
>make[1]: Entering directory `/c/thesrc/postgis-1.4.0rc2/doc'
>make[1]: Leaving directory `/c/thesrc/postgis-1.4.0rc2/doc'
>make -C regress clean
>make[1]: Entering directory `/c/thesrc/postgis-1.4.0rc2/regress'
>rm -f postgis.sql
>make[1]: rm: Command not found
>make[1]: *** [clean] Error 127
>make[1]: Leaving directory `/c/thesrc/postgis-1.4.0rc2/regress'
>make: *** [test-clean] Error 2
>Leo
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net
>[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
>Cave-Ayland
>Sent: Monday, July 13, 2009 7:26 AM
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] problem with makefile in MinGW in trunk
>nicklas.aven at jordogskog.no wrote:
>> Then it seems to give exactly the same error-messages as in branch 1.4
>> is it something strange with my mingw-installation or is it the same
>> thing for you Regina?
>> or anyone else compiling with MinGW
>> /Nicklas
>How strange. What does PATH look like in a plain MSYS shell? Can you type
>"make" on its own within that? And what are the exact errors you are seeing?
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS Sirius
>Corporation plc - control through freedom http://www.siriusit.co.uk
>t: +44 870 608 0063
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090713/42059588/attachment.html>
