[postgis-devel] [PostGIS] #222: GUI compile under MinGW
trac at osgeo.org
Mon Jul 13 13:15:56 PDT 2009
Reporter: pramsey | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.0
Component: postgis | Version: 1.4.X
Resolution: | Keywords:
Comment (by mcayland):
Hmmm looks like I missed one asprintf() in the last patch - try the
attached patch.
Note that this still doesn't solve the problem with the encoding variable.
Paul, what should happen to this if you're not building with iconv -
should this section of code simply be wrapped in a #ifdef HAVE_ICONV ...
#endif?
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/222#comment:4>
