[postgis-devel] Multi-D Indexing and Serialized Form
Paul Ramsey pramsey at opengeo.org
Mon Jul 13 15:08:59 PDT 2009
On Mon, Jul 13, 2009 at 2:44 PM, Chris Hodgson<chodgson at refractions.net> wrote:
> Oh, I understand, you're not talking about what dimension of bbox gets
> stored in the index, you're talking about how many dimensions the bbox in
> the geometry object is... in which case, I think you're straight-line
> solution seems to make the most sense. Otherwise it is an additional
> parameter that you have to specify when you create your geometry column -
> how many dimensions is the bbox.
Right, uuuuugLY.
P.
> Chris
> Paul Ramsey wrote:
>> Yes, if we are willing to re-calculate the full bounding box for
>> comparison purposes, every time we need it. For large geometries, this
>> is a bad trade-off. But that speaks again to simply calculating the
>> fully dimensional bbox. We don't currently have a very clever use of
>> the clever "optional bbox" trick dave baked into the initial revision,
>> but that clever trick gets us a long way if we don't use bboxes at all
>> for smaller geometries that we are fine with calculating the bbox for
>> every time.
>> O
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
