[postgis-devel] problem with makefile in MinGW in trunk
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Tue Jul 14 02:21:24 PDT 2009
nicklas.aven at jordogskog.no wrote:
> Yes, the patch helped "make clean", but "make check" still gives:
> make[1]: Leaving directory `/c/thesrc/pg15/liblwgeom/cunit'
> make -C regress check
> make[1]: Entering directory `/c/thesrc/pg15/regress'
> sed 's,$libdir/postgis,/c/thesrc/pg15/regress/../postgis/libpostgis,g'
> ../postgis/postgis.sql > postgis.sql
> ./run_test: psql: command not found
> Creating spatial db postgis_reg
> ./run_test: createdb: command not found
> ./run_test: createlang: command not found
>  Something went wrong (no postgis installed in postgis_reg).
>  For details, check /tmp/pgis_reg_4372/regress_log
> make[1]: *** [check] Error 1
> make[1]: Leaving directory `/c/thesrc/pg15/regress'
> make: *** [check] Error 2
> Thanks
> Nicklas
Yeah, it still doesn't like the colons :(   I'll see if I can come up
with something better over the next couple of days with my Windows VM...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
