[postgis-devel] st_intersect crasher
Paragon Corporation lr at pcorp.us
Wed Jul 15 03:28:05 PDT 2009
For what its worth, I did test his binary example against my geos 3.1.1
under windows and it worked fine.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Wednesday, July 15, 2009 5:01 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] st_intersect crasher
David Fuhry wrote:
> Mark,
>    Thanks for the coverage.  After checking, I'm pretty sure now that
> the GEOS 3.1.1 used below is the release version (not from svn).
>    I'm willing to try geos svn then bisect, but automake is failing on
> my Debian system:
> ~/geos$ ./autogen.sh
> * Running /usr/bin/libtoolize (1.5.22) \tOPTIONS = --force --copy You
> should add the contents of `/usr/share/aclocal/libtool.m4' to
> `aclocal.m4'.
> * Running /usr/bin/aclocal (1.4-p6)
> * Running /usr/bin/autoheader (2.61)
> * Running /usr/bin/automake (1.4-p6)
> \tOPTIONS = --add-missing --copy
> automake: configure.in: installing `./install-sh'
> automake: configure.in: installing `./mkinstalldirs'
> automake: configure.in: installing `./missing'
> configure.in: 40: required file `./[source/headers/config.h].in' not
> found
> configure.in: 40: required file `./[source/headers/stamp-h1.in' not
> found
> configure.in: 40: required file `./[source/headers/geos/platform.h].in'
> not found
> configure.in: 40: required file `./[source/headers/geos/stamp-h2.in'
> not found
> capi/Makefile.am:10: invalid variable `nodist_capi_HEADERS'
> source/operation/buffer/Makefile.am:7: variable `NULL' not defined
> automake: source/operation/overlay/Makefile.am: not supported: source
> file `snap/GeometrySnapper.cpp' is in subdirectory ...
> automake: tests/xmltester/Makefile.am: not supported: source file
> `markup/MarkupSTL.h' is in subdirectory
>   Something went wrong, giving up!
> -Dave
Hi Dave,
Is this from an SVN checkout or a release tarball? If it's from the tarball,
can you try from a checkout instead?
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
