[postgis-devel] problem with makefile in MinGW in trunk
nicklas.aven at jordogskog.no
Thu Jul 16 13:48:52 PDT 2009
Great
I will try it tomorrow.
/Nicklas
2009-07-16 Mark Cave-Ayland wrote:
nicklas.aven at jordogskog.no wrote:
>> Yes, the patch helped "make clean", but "make check" still gives:
>> make[1]: Leaving directory `/c/thesrc/pg15/liblwgeom/cunit'
>> make -C regress check
>> make[1]: Entering directory `/c/thesrc/pg15/regress'
>> sed 's,$libdir/postgis,/c/thesrc/pg15/regress/../postgis/libpostgis,g'
>> ../postgis/postgis.sql > postgis.sql
>> ./run_test: psql: command not found
>> Creating spatial db postgis_reg
>> ./run_test: createdb: command not found
>> ./run_test: createlang: command not found
>> Something went wrong (no postgis installed in postgis_reg).
>> For details, check /tmp/pgis_reg_4372/regress_log
>> make[1]: *** [check] Error 1
>> make[1]: Leaving directory `/c/thesrc/pg15/regress'
>> make: *** [check] Error 2
>> Thanks
>> Nicklas
>Okay - please try the attached. This seems to get regression tests
>working for me, but pgsql2shp/shp2pgsql seem to give multiple WKB
>regression failures :(
>Can anyone else confirm?
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090716/a43efeea/attachment.html>
