[postgis-devel] [PostGIS] #129: Test 1.4 against Windows
PostGIS trac at osgeo.org
Fri Jul 17 07:49:15 PDT 2009
  Reporter:  pramsey   |       Owner:  mcayland
      Type:  task      |      Status:  assigned
  Priority:  medium    |   Milestone:  postgis 1.4.0
 Component:  postgis   |     Version:  1.4
Resolution:  accepted  |    Keywords:
Comment (by mcayland):
 What do the loader diffs look like? On my Win32 virtual, it looks as if
 there is random corruption in the Z/M coordinates :(
 Incidentally all of the other non-loader tests look fine for me, although
 I did have to run dos2unix on all of the input .sql and _expected output
 files.
 Oh and one more thing: can you launch shp2pgsql/pgsql2shp directly from
 the command line? If you try and launch each with no parameters, you
 should be able to see the help text - if there is a .DLL missing then
 you'll get a suitable popup.
 ATB,
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/129#comment:11>
