[postgis-devel] [PostGIS] #129: Test 1.4 against Windows
trac at osgeo.org
Tue Jul 21 23:54:38 PDT 2009
Reporter: pramsey | Owner: mcayland
Type: task | Status: assigned
Priority: medium | Milestone: postgis 1.4.0
Component: postgis | Version: 1.4
Resolution: accepted | Keywords:
Comment (by robe):
I was using a MingW compiled 8.3. I was actually able to eventually
compile it again under MingW after deleting my install director. It seems
that somehow our make check is messing up the path or something in MingW
is messing up the path. I couldn't find more anywhere, but noticed that
if I launched
my 8.3 psql from within MinGW and did a
help, I got the same more error. So I think its the psql that is somehow
triggering it. why it doesn't trigger it for my MingW installed
PostgreSQL 8.4 I have no clue.
But running my 8.3 psql outside of MingW seems to work fine.
Note that I don't believe MingW includes more. All articles I read seem
to suggest using less instead of more (perhaps maybe 8.4 is using less?).
But copying my more.com from windows (and even renaming it to more.exe and
putting in my msys/1.0/bin doesn't seem to resolve the situation).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/129#comment:21>
