[postgis-devel] Vote for 1.4 Release
Kevin Neufeld
kneufeld at refractions.net
Wed Jul 22 15:21:58 PDT 2009
The problem is with the regression Makefile, I don't know how exactly.
I can run the run_test manually and all regression tests pass without incident.
[postgres at turtle regress]$ ./run_test loader/Point \
? loader/PointM \
? loader/PointZ \
? loader/MultiPoint \
? loader/MultiPointM \
? loader/MultiPointZ \
? loader/Arc \
? loader/ArcM \
? loader/ArcZ \
? loader/Polygon \
? loader/PolygonM \
? loader/PolygonZ \
? regress \
? regress_index \
? regress_index_nulls \
? lwgeom_regress \
? regress_lrs \
? removepoint \
? setpoint \
? simplify \
? snaptogrid \
? affine \
? wkt \
? measures \
? long_xact \
? ctors \
? sql-mm-serialize \
? sql-mm-circularstring \
? sql-mm-compoundcurve \
? sql-mm-curvepoly \
? sql-mm-general \
? sql-mm-multicurve \
? sql-mm-multisurface \
? geojson \
? gml \
? svg \
? kml \
? regress_ogc \
? regress_bdpoly \
? regress_proj
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_7027
PATH is /usr/local/bin:/bin:/usr/bin:/opt/pgsql837/bin
PostgreSQL 8.3.7 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
Postgis 1.4.0SVN - 2009-07-22 21:44:30
GEOS: 3.1.0-CAPI-1.5.0
PROJ: Rel. 4.4.9, 29 Oct 2004
Running tests
loader/Point.............. ok
loader/PointM.............. ok
loader/PointZ.............. ok
loader/MultiPoint.............. ok
loader/MultiPointM.............. ok
loader/MultiPointZ.............. ok
loader/Arc.............. ok
loader/ArcM.............. ok
loader/ArcZ.......... ok
loader/Polygon.............. ok
loader/PolygonM.............. ok
loader/PolygonZ.............. ok
regress. ok
regress_index. ok
regress_index_nulls. ok
lwgeom_regress. ok
regress_lrs. ok
removepoint. ok
setpoint. ok
simplify. ok
snaptogrid. ok
affine. ok
wkt. ok
measures. ok
long_xact. ok
ctors. ok
sql-mm-serialize. ok
sql-mm-circularstring. ok
sql-mm-compoundcurve. ok
sql-mm-curvepoly. ok
sql-mm-general. ok
sql-mm-multicurve. ok
sql-mm-multisurface. ok
geojson. ok
gml. ok
svg. ok
kml. ok
regress_ogc. ok
regress_bdpoly. ok
regress_proj. ok
Run tests: 40
Failed: 0
-- Kevin
Kevin Neufeld wrote:
> I did a new install of postgres 8.3.7 and of postgis branch 1.4 just to
> be sure that this wasn't an svn update thing. So new directories, new
> everything.
> Paragon Corporation wrote:
>> Strange. Did you do a fresh download of the source (not just an svn
>> update
>> but a full delete and svn checkout?). Thes al seem like old errors I
>> experienced before.
>> For psql I would think maybe it can't find libpq.so but didn't know the
>> others relied on that.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
