[postgis-devel] Vote for 1.4 Release
Paragon Corporation
lr at pcorp.us
Wed Jul 22 15:49:27 PDT 2009
Kevin,
If you want to take it out, feel free too. I suspect maybe he did that
because of spaces allowed in folder names in windows. I had so many
problems with that anyway that I installed mytest postgres servers in
folders that required no spaces.
I think Nick just hacked his make file to bits to work and I always did an
export path anyway before I did a make check.
I wonder what happens if your path already has quotes in it? What would that
line do?
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Kevin
Neufeld
Sent: Wednesday, July 22, 2009 6:30 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Vote for 1.4 Release
Found it. This is the change that broke the Makefile for me:
http://trac.osgeo.org/postgis/changeset/4320
Mark added quotes around the PATH. My linux distros don't like that
apparently.
-- Kevin
Kevin Neufeld wrote:
> The problem is with the regression Makefile, I don't know how exactly.
> I can run the run_test manually and all regression tests pass without
> incident.
> [postgres at turtle regress]$ ./run_test loader/Point \
> ? loader/PointM \
> ? loader/PointZ \
> ? loader/MultiPoint \
> ? loader/MultiPointM \
> ? loader/MultiPointZ \
> ? loader/Arc \
> ? loader/ArcM \
> ? loader/ArcZ \
> ? loader/Polygon \
> ? loader/PolygonM \
> ? loader/PolygonZ \
> ? regress \
> ? regress_index \
> ? regress_index_nulls \
> ? lwgeom_regress \
> ? regress_lrs \
> ? removepoint \
> ? setpoint \
> ? simplify \
> ? snaptogrid \
> ? affine \
> ? wkt \
> ? measures \
> ? long_xact \
> ? ctors \
> ? sql-mm-serialize \
> ? sql-mm-circularstring \
> ? sql-mm-compoundcurve \
> ? sql-mm-curvepoly \
> ? sql-mm-general \
> ? sql-mm-multicurve \
> ? sql-mm-multisurface \
> ? geojson \
> ? gml \
> ? svg \
> ? kml \
> ? regress_ogc \
> ? regress_bdpoly \
> ? regress_proj
> Creating spatial db postgis_reg
> TMPDIR is /tmp/pgis_reg_7027
> PATH is /usr/local/bin:/bin:/usr/bin:/opt/pgsql837/bin
> PostgreSQL 8.3.7 on i686-pc-linux-gnu, compiled by GCC gcc (GCC)
> 3.4.4
> 20050721 (Red Hat 3.4.4-2)
> Postgis 1.4.0SVN - 2009-07-22 21:44:30
> GEOS: 3.1.0-CAPI-1.5.0
> PROJ: Rel. 4.4.9, 29 Oct 2004
> Running tests
> loader/Point.............. ok
> loader/PointM.............. ok
> loader/PointZ.............. ok
> loader/MultiPoint.............. ok
> loader/MultiPointM.............. ok
> loader/MultiPointZ.............. ok
> loader/Arc.............. ok
> loader/ArcM.............. ok
> loader/ArcZ.......... ok
> loader/Polygon.............. ok
> loader/PolygonM.............. ok
> loader/PolygonZ.............. ok
> regress. ok
> regress_index. ok
> regress_index_nulls. ok
> lwgeom_regress. ok
> regress_lrs. ok
> removepoint. ok
> setpoint. ok
> simplify. ok
> snaptogrid. ok
> affine. ok
> wkt. ok
> measures. ok
> long_xact. ok
> ctors. ok
> sql-mm-serialize. ok
> sql-mm-circularstring. ok
> sql-mm-compoundcurve. ok
> sql-mm-curvepoly. ok
> sql-mm-general. ok
> sql-mm-multicurve. ok
> sql-mm-multisurface. ok
> geojson. ok
> gml. ok
> svg. ok
> kml. ok
> regress_ogc. ok
> regress_bdpoly. ok
> regress_proj. ok
> Run tests: 40
> Failed: 0
> -- Kevin
>> I did a new install of postgres 8.3.7 and of postgis branch 1.4 just
>> to be sure that this wasn't an svn update thing. So new directories,
>> new everything.
>> Paragon Corporation wrote:
>>> Strange. Did you do a fresh download of the source (not just an svn
>>> update but a full delete and svn checkout?). Thes al seem like old
>>> errors I experienced before.
>>> For psql I would think maybe it can't find libpq.so but didn't know
>>> the others relied on that.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
