[postgis-devel] Typmod Again
Paul Ramsey
pramsey at opengeo.org
Wed Jul 22 16:05:10 PDT 2009
FYI, I'm implementing this stuff within the context of GEOGRAPHY,
which allows us to sort of play with these ideas before rolling them
onto GEOMETRY in a breaking way. I do think that trying to hew closer
to the standards base for GEOMETRY when we do the 2.0 release would be
a good idea, try to put all the breaking changes we can think of into
one release.
P.
On Wed, Jul 22, 2009 at 2:30 PM, Paragon Corporation<lr at pcorp.us> wrote:
> No we don't
> POINTZ, POLYGONZ POLYGONZM, POINTZM -> just POINT, POLYGON -- so we have
> POINT(1 2 3), POINT(1 2 3 4)
> Technically I believe we are in violation of the standards here. So Paul's
> proposal -- while a breaking change would be more compliant.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Chris
> Hodgson
> Sent: Wednesday, July 22, 2009 5:25 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Typmod Again
> According to the 1.4 manual, postgis has the following type options:
> The type of the spatial object. To restrict the spatial column to a single
> type, use one of: POINT, LINESTRING, POLYGON, MULTIPOINT, MULTILINESTRING,
> MULTIPOLYGON, GEOMETRYCOLLECTION or corresponding XYM versions POINTM,
> LINESTRINGM, POLYGONM, MULTIPOINTM, MULTILINESTRINGM, MULTIPOLYGONM,
> GEOMETRYCOLLECTIONM. For heterogeneous (mixed-type) collections, you can use
> "GEOMETRY" as the type.
> I don't see any Z options, let alone GEOMETRYZ/M. Do we really have
> different types for each possible type and 2/3/4-d combination?
> Chris
> Paul Ramsey wrote:
>> OK, working into the typmod implementation, I found this interesting
> quirk.
>> Before, I was talking about
>> geometry(srid, type, dims)
>> But, in fact, dims is implicit in type, and you probably want that.
>> IE, 'POINTZM' (as defined in Table 4 of SFSQL 1.2.0) is a valid type,
>> and implies a dimensionality of four. We want our types to include
>> that information so we can distinguish between POINTM and POINTZ,
>> otherwise, we could define geometry(4326, POINT, 3) and be able to
>> accept both POINTM and POINTZ.
>> So that brings us down to just
>> geometry(srid, type)
>> Anything I'm missing?
>> P
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
