[postgis-devel] [WKT Raster] Plan to add ST_AsBinary
Mateusz Loskot
mateusz at loskot.net
Thu Jul 30 03:54:19 PDT 2009
First, the announcement:
I'm planning to implement ST_AsBinary function to WKT Raster, so users
who work with binary cursors can avoid (significant) overhead of
encoding raster data to hex form and back.
The ST_AsBinary(rast) function has been planned [1] already (see
RT_AsBinary, old name).
Obviously, I'll follow PostGIS best practice and try to get the solution
aligned to PostGIS' ST_AsBinary in terms of syntax and semantic.
Second, I'd like to ask for a piece of advice.
Currently, we have ST_bytea function in WKT Raster which seems to
provide most of the features I need for ST_AsBinary.
The missing ones are handling endianness.
I see that PostGIS still provides ST_bytea function for geometry.
However, I can't find it in the documentation [2]
What I'm looking for is what's the difference between ST_AsBinary and
ST_bytea, in PostGIS. Both functions are based on WKBFromLWGEOM, so I
assume they return object of exactly the same type. AFAIU, the
difference is that ST_AsBinary enables users to choose endianness of
output binary.
Am I right? Is that all or something is missing?
Third, current roadmap defines only one version of (R)ST_AsBinary:
RT_AsBinary(raster, compression)
I'm thinking about extending it two four versions:
Initially, implement non-compressing version of ST_AsBinary for WKT Raster:
ST_AsBinary( rast ) - this is equivalent to ST_bytea ST_AsBinary( rast,
endianness )
The compressing one can be added later as it is planned:
ST_AsBinary( rast, compression ) - equivalent to st_bytea but with
compression applied ST_AsBinary( rast, compression, endianness )
I would appreciate any comments and suggestions to this idea.
[1] http://trac.osgeo.org/postgis/wiki/WKTRaster/PlanningAndFunding
[2] http://postgis.refractions.net/documentation/manual-1.4/ch07.html
Best regards,
Mateusz Loskot
Senior Programmer, Cadcorp
http://www.cadcorp.com
