[postgis-devel] [PostGIS] #219: Run 'make check' without needing 'make install' first
trac at osgeo.org
Thu Jul 30 09:18:56 PDT 2009
Reporter: pramsey | Owner: pramsey
Type: enhancement | Status: reopened
Priority: medium | Milestone: postgis 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
Looking at this with a fresh pair of eyes, I think the simple approach
implemented in SVN trunk is wrong. This is because the name of the source
library .so/.dll before the copy to the PostgreSQL installation directory
can very between platforms, and so only PGXS can know the correct voodoo
to install it.
I think that a better approach would be to alter the regression Makefile
so that it does "make DESTDIR=regress/tmp -f ../Makefile" to install the
binaries in a subdirectory under regression, and then use the files in
this location which should resolve the issue.
ATB,
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/219#comment:9>
