[postgis-devel] Adding out-db rasters support to gdal2wktraster
Jorge Arévalo
jorge.arevalo at gmail.com
Fri Jul 31 01:58:15 PDT 2009
2009/7/27 Mateusz Loskot <mateusz at loskot.net>:
> Jorge Arévalo wrote:
>> I've been working on a TODO task of gdal2wktraster script. The support
>> for out-db rasters. My point is to create a blank tiff raster and fill
>> it with the bands of the original one. The name of the new raster is
>> automatically generated based on the name of the original file.
> OK
>> It should be necessary to add a path before the name of the file in
>> hexwkb string. I'm sure there are more errors. For this reason, I send
>> my version to the community, and specially to Mateusz. I'll be really
>> pleased to know my errors, and if this code helps.
> It would be better if you could generate patch with your changes against the
> version of gdal2wktraster from Subversion repository and submit it as ticket
> with patch attached.
> http://trac.osgeo.org/postgis/
> This is one of the most efficient ways to submit a code and ask for review.
> See example of such ticket.
> http://trac.osgeo.org/geos/ticket/278
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
Ok Mateusz. I'll do it. Thanks!
Best regards
Jorge
