[postgis-devel] [PostGIS] #500: [wktraster] ST_MakeEmptyRaster xml documentation return type is wrong
trac at osgeo.org
Wed Jul 15 13:24:02 PDT 2009
Reporter: pracine | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by robe):
I use JEdit or Notepad++, but any color coding editor with tag matching
capability should do fine.
The two files are reference_wktraster.xml and faq_wktraster.xml in
trunk/doc folder.
I also have a wktraster_comments.sql.xsl file which I use to build the
postgresql in db help for raster that is packaged with the win32 binaries.
Haven't automated the generation of this yet in the make scripts.
Anyrate all you need to do is edit the xml files and Hudson builds
everything for you and will send you a failed note if you break something.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/500#comment:2>
