[postgis-devel] Re: [PostGIS] #101: ST_Union on one-row table doesn't union
trac at osgeo.org
Tue Jun 2 23:04:40 PDT 2009
Reporter: pramsey | Owner: pramsey
Type: defect | Status: assigned
Priority: medium | Milestone: postgis 1.4.0
Component: postgis | Version: 1.4
Resolution: accepted | Keywords:
Comment (by robe):
Paul is this really a PostGIS problem or a GEOS one. Not knowing c from a
hole in the wall-- it seems we are recursing thru the polygons just to
allocate enough space for a GEOS lwpoly. So its GEOS that is not dealing
with unioning a single multipolygon correctly. Its probably assuming --
its already one geometry why bother.
I would have thought unioning with an empty geometry collection would
solve the issue but doesn't seem too either -- get back the same dumb
invalid multipolygon
SELECT ST_OrderingEquals(ST_Union(ST_GeomFromText('GEOMETRYCOLLECTION
EMPTY'),the_geom),the_geom) FROM testunion;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/101#comment:10>
